How To Fit A Bottombracket.
Trials_joe
You will need:
Lots of Grease
8mm allen key
Crank puller
Splined BB tool
Large adjustable spanner
I find it easier to wash my bike before i go putting any new stuff on because you may put you hand in some dirt or dog mess.
1. Take crank arms off. To do this, undo the 8mm Allen key bolt. Take your crank puller and apply a small amount of grease on the threads as this will help to not strip the threads inside. Screw in the crank puller and turn clockwise. Slowly the crank will start to come off. You need to do this on both sides.
2. Now to taking out the actual Bb. Start on the left side (Which is the Non-Drive side) you need to but your Bb tool into the located positions. Once in make sure you hold the tool in position whilst turning it Anti-clockwise.
3. Now you need to take of the Right hand side (Which is the Drive side). Do exactly the same before making sure the tool doesn’t slip off. This time it you need to turn it clockwise.
4. Once removed you need to degrease/Clean the threads make sure there’s no dirt what so ever. This is because the dirt might damage your threads.
5. Now apply LOTS of grease (This may get a little messy). Now comes to fitting your new bottom bracket. Start with the left hand cup (Non-Drive side). Screw it in Clockwise, using your fingers, as it shouldn’t be that tight.
6. Now its time for the Drive side. This needs to be screwed in Anti-Clockwise into the frame. Again using your fingers.
7. Now you need to tighten it all up (Using your BB tool and Spanner). Do each side in turn. So tighten left-side two rotations and the right-side two. As the cups get closer to the frame you will not need to turn it that much. Now check it’s all tight and flush against the frame.
8. Finally attach you crank arms. You can put a light smear of grease on the Bb axle and on the Crank bolts. Then clean it all up. Pack your tools away and enjoy a non-creaking, smooth Bb.
If your Bb is creaking on your first ride this maybe because you need to 'face' your Bb shell. Any Good Bike store can do this.
I’m not taking a responsibility for any damage done to your bike, yourself or your mums new carpet. (Y)
Hope it helps. :-
