Joe_Elding Posted November 29, 2005 Report Share Posted November 29, 2005 Hi, I'll probably be building up a stock after chrismtmas 'because my mates got a new frame so can sell me his Ali bongo. I've got a plan sorted in my head theres just a few things I need reccomendations on: Forks: i liked his bike which had fatty forks on but I've been told you can't get these any more? So something a simalar length please, preferably 2bolt/disc Rims: I'll probably buy a mavic wheel off my mate for the front but what what is there for the back? I could pick up a mavic pretty cheaply but i heard there too thin for most frames? Stems: I'll be riding mostly street but will do the odd sidehops and gaps etc. What stems would you recommend, Toxsin looks alright? or the echo ones? Cheers :) Quote Link to comment Share on other sites More sharing options...
shovel Posted November 29, 2005 Report Share Posted November 29, 2005 for forks echo urbans would be a good choice, i've just changed from a set of fatty-r forks to these in 4-bolt and they are very good, bit lighter about 10mm longer and a bit stiffer too, they're also available in 2 bolt mounts/disc option too, looking at £82 for them for the rear rim you won't want something too wide for the frame so an onza ronnie rim would probably be a good choice, about £35 for that i think the stem will come down to personal preference in the end but any of them would do, maybe 100mm 5 degree would be about right for what your doing, varies though, some people like long stems some like short, up to you on that one Quote Link to comment Share on other sites More sharing options...
Felix Posted November 29, 2005 Report Share Posted November 29, 2005 I had a 28mm Mavic and a 38mm DX32 in my Ali Bongo. Both fit fine. With a V-brake that is. I'd go with a stem that is about 15°x100mm. Maybe a bit shorter if you like it streety. 5° will definitely be too low, because of the bb rise. Unless you're a fan of super low bars :) Quote Link to comment Share on other sites More sharing options...
