Bleeding Magura Louise Discs?
Joe_Elding
Okay I'm definately sure my brake needs a re-bleed 'because ive set it up so te pads are on the rotor completely and the lever squeezes in.
Anyway how do you do it?
I've heard you just fill the reservoir up, pump the lever and repeat until no bubbles come out anymore?
Is that true, I've had a look at the magura website but don't understand it.
Any how to's anywhere, is it the same for hope discs?
Cheers
you can bleed the brake like that but its a bit of a shortcut and the brake will feel crap
you will need:
-bleed kit (sirynge, tube, connecter for screwing into caliper)
-mineral oil (preferibly magura blood)
-allen keys
-think magura resevoirs use a small torx bit, so that too
lean bike up against wall, position brake lever so resevoir is sitting horizontal, fill up syringe with magura blood/any other suitable fluid, make sure there's no air bubbles in tube or syringe
unscrew grub screw from disc caliper and srew in tubing using attatchment on bleed kit, only needs to be hand tight, now unscrew the resevoir top cap from the brake lever, you might want to put an old basin under the brake lever at this point
pump the fluid through the syringe, you should see fluid overflowing from the resevoir at this point, keep doing this until the fluid overflowing looks like the new stuff and until theres no air bubbles coming out
now replace the resevoir top cap and then remove the syringe and tighten the grub screw back into the caliper
jobs a good un' :)
you will need:
-allen keys
jobs a good un' :)
Cheers is it the same size caliper fitting thing as for an hs33?
  • 3 years later...
