Gandalf the Yellow Posted November 23, 2005 Report Share Posted November 23, 2005 i was browsing today and on www.trials-uk.co.uk i saw VIZ rims coming in smaller sizes! perfect, as my giant don't like chunky rims 42mm+. only problem is i current run XTR/SD7 front v brake and the site doesn't tell me whether i can run my rim brake or i have to make a switch to disc. (or its possible to grind sidewalls to work with rim brakes?) now i also need some white rim tapes if i go for them rims, does anyone know where i can get some? or any alternatives i can use that is white? thanks for the help guys. steve (Y) Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted November 23, 2005 Report Share Posted November 23, 2005 Yeh, its ok, Ive been running one on the front for aaages. Rode it mainly on its origional anodised surface, and it was ok, now Ive put a light grind on it and its a little bit better, but not much difference. Dont viz do coloured rim tape too? They might do white, I dunno Quote Link to comment Share on other sites More sharing options...
Alexxx Posted November 23, 2005 Report Share Posted November 23, 2005 go to B and Q and you can buy big packs of tape....they come in white....thats what i did anyway alex Quote Link to comment Share on other sites More sharing options...
br3n Posted November 24, 2005 Report Share Posted November 24, 2005 you can get coloured rimtapes from trials-uk as well... and yes you can grind the viz rims or just leave the anadised surafce and it should be ok. Quote Link to comment Share on other sites More sharing options...
James_Porter Posted November 24, 2005 Report Share Posted November 24, 2005 viz ehhhhhhhhhh its like that shitty wannabe fake cokeacola you get for 10p at your local indian shop...WHICH they have spiked to make it even worse. and they have a gay apollo line, which just makes the rims weak as f**k. Quote Link to comment Share on other sites More sharing options...
Janson Posted November 24, 2005 Report Share Posted November 24, 2005 i'm with porter, tryall is where it's at. :P Quote Link to comment Share on other sites More sharing options...
Dan@Trials-uk Posted November 24, 2005 Report Share Posted November 24, 2005 viz ehhhhhhhhhh its like that shitty wannabe fake cokeacola you get for 10p at your local indian shop...WHICH they have spiked to make it even worse. and they have a gay apollo line, which just makes the rims weak as f**k. :P Ive had my rim for along time now, looooooads of grinds and its still fine? the line on the rim surface dont actually affected it. The try-all seems to dent easier :P with no grind aswell(N) Quote Link to comment Share on other sites More sharing options...
Houseface Posted November 24, 2005 Report Share Posted November 24, 2005 go for try-all, they are stronger :P steve. Quote Link to comment Share on other sites More sharing options...
Nick Manning Posted November 24, 2005 Report Share Posted November 24, 2005 im still on the same pair of viz rims since about june, and ive seen plenty of people go through other branded rims since to now, i agree on the koxx rims, they do seem to dent quite easily. havent tried any rims, but too be fair the best rims about have to mavic EX721 but there just not wide enough for modern trials frames. Quote Link to comment Share on other sites More sharing options...
Gandalf the Yellow Posted November 24, 2005 Author Report Share Posted November 24, 2005 im still on the same pair of viz rims since about june, and ive seen plenty of people go through other branded rims since to now, i agree on the koxx rims, they do seem to dent quite easily. havent tried any rims, but too be fair the best rims about have to mavic EX721 but there just not wide enough for modern trials frames. yea you're probably right, im running these mavics at the moment but i feel i need a slightly wider rim thats just as strong( maybe not going to happen), also good with grinds so i thought the viz will do the better jobby with the colours and eyelets and all that. tryall don't come eyeletted so why doesn;t anyone mention the onza hogs?...they're the eyeletted version of tryalls so in theory they're a bit of a stronger build. i wish mavic did wider EX721 rim thingy ma jiggys. anyways thanks for the help guys. appreciated. steve :P Quote Link to comment Share on other sites More sharing options...
downhill_rob2@hotmail.com Posted November 25, 2005 Report Share Posted November 25, 2005 Simple solution..... Echo 2006 rims :P Quote Link to comment Share on other sites More sharing options...
