Easton Ea50 Riser Bar Questions
toyota200x
Hello............
I have a Brisa b26d and I am looking to make it more streety. I have wide bulge bars on it now and I am not liking it for bunny hops. So I have been looking for some DH looking bars and came across the EASTON EA50 RISER BAR which is 26" wide. What do people think of this bar? I can get is for $24 plus a little shipping. Let me know please. Thank you.................
I've just ordered a set for my Brisa, but for the opposite reason - I want to make it more trialsy (if that is indeed possible with such a frame). I currently have DMR wingbars with 3" rise and it bunnyhops real nice though it is worse for proper trials stuff like sidehops and gaps.
Your stem length and rise will also effect things. Go for a shorter higher rise stem, say a 90mm 20 degree one and that should make it better for street stuff. In general high front end = street, low = trials. It's up to you to find the perfect balance since everyone's style is different.
Hope that helps
Daniel
Edited by djb
Hope that helps
Daniel
So do you think the EA50 is going to do the trick if I have a higher rise stem? DO you think you will make yours more trails like with the EA50? I have a brisa stem right now with a Brisa bar. What diameter are Brisa bars? Thank you
