Allen Key Bolts For Monty Hubs
Houseface
If you already have the grippy washer thing you could easily go into a local hardwear shop and buy some 10mm bolts with the same thread. You will also have to add a couple of washers to space the bolt out enough to tighten it. If you go down this route you wont have to worry about rounding stupid allen bolts :P
Also 10mm bolts will take a pounding and you will still be able to get them off no problems!
