Dan6061 Posted November 22, 2005 Report Share Posted November 22, 2005 Decided to take off both brakes to give them a fresh water bleed. Front went all smoothly, and blled felt perfect. Rear lever piston was stuck in the lever body. Managed to get it out, but it looks 'chewed' and fecked. I've tried oiling it, same thing happens, it just doesnt spring back at all. Pictures: Notice how it's not 'sticking out' like my over lever: Notice it? Here's a picture of the front of the lever with the stuck piston: Notice how 'chewed' it looks? 1) Will it still be alright to use? 2) Do I need a new piston? 3) Where can I get a new piston from if I need to (CRC don't have them seperate, only full levers) 4) If you have a spare one, how much? Cheers guys :P Quote Link to comment Share on other sites More sharing options...
nb88 Posted November 23, 2005 Report Share Posted November 23, 2005 Did it keep getting stuck after being bled, with a lever blade fitted? If so its probably worth putting up a for sale/wanted post for an entire lever, wont be much. Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted November 23, 2005 Report Share Posted November 23, 2005 Shove some grease on the o ring and put it back in. Then bleed it and pump it loads to wear it in Quote Link to comment Share on other sites More sharing options...
Dan6061 Posted November 23, 2005 Author Report Share Posted November 23, 2005 Should be able to get a new piston tomorrow. Mate's brother bought a new set of Magura's and has spares :) Will try oiling the O ring when I get home :P Quote Link to comment Share on other sites More sharing options...
