nicky Posted November 22, 2005 Report Share Posted November 22, 2005 when i pedal my bike doesnt go anywhere and makes this noise. it only happens sometimes though. i heard it was the bearings slipping in the bottom bracket. Quote Link to comment Share on other sites More sharing options...
SuperDeathMonkey Posted November 22, 2005 Report Share Posted November 22, 2005 If you're pedaling and your bike isn't moving sounds like you're freewheel or freehub skipping Quote Link to comment Share on other sites More sharing options...
nicky Posted November 22, 2005 Author Report Share Posted November 22, 2005 ok thanks for the help. it feels like its coming from the bottom bracket though. Quote Link to comment Share on other sites More sharing options...
SuperDeathMonkey Posted November 22, 2005 Report Share Posted November 22, 2005 You might have rounded the cranks so they are just spinning round the axel Quote Link to comment Share on other sites More sharing options...
llandudno_trialsboy Posted November 22, 2005 Report Share Posted November 22, 2005 probably is the freewheel. What freewheel or free hub you running? hope you get it fixed Quote Link to comment Share on other sites More sharing options...
Concussion Posted November 22, 2005 Report Share Posted November 22, 2005 You haven't rounded off your chainring ring teeth have you? Quote Link to comment Share on other sites More sharing options...
nicky Posted November 22, 2005 Author Report Share Posted November 22, 2005 would i need a new crank? because ive got another crank the same as it. so changing the cranks is not a problem Quote Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2005 Report Share Posted November 22, 2005 No, if your pedalling and not going anywhere its the freewheel/freehub as someone else said, unless of course you have no teeth on your chainring(as someone else said) but in that case your chain would constantly fall off. iIf you can turn the pedals, then the cranks taper wouldnt be broken. What type of bike it is?? Quote Link to comment Share on other sites More sharing options...
JT! Posted November 22, 2005 Report Share Posted November 22, 2005 As said above it most likely the freewheel rounding out. Just replace the freewheel (ACS clause will do) and just get your local bike shop to put it on. It wont be your bottom bracket, as if it was knackerd, the cranks would still turn round. Quote Link to comment Share on other sites More sharing options...
James_Richardson Posted November 22, 2005 Report Share Posted November 22, 2005 Could very well be the BB threads going, thats what happened with mine. Or the internals of the BB. Quote Link to comment Share on other sites More sharing options...
nicky Posted November 22, 2005 Author Report Share Posted November 22, 2005 the bike is a base ta26 but has a truvativ isis drive hussefelt crank on. Quote Link to comment Share on other sites More sharing options...
Guest Posted November 22, 2005 Report Share Posted November 22, 2005 As said above it most likely the freewheel rounding out. Just replace the freewheel (ACS clause will do) and just get your local bike shop to put it on. It wont be your bottom bracket, as if it was knackerd, the cranks would still turn round. Which threads? If it was the bottom bracket and the cranks were still turning, which I understand they are, he would still get drive when the cranks turned clockwise. Quote Link to comment Share on other sites More sharing options...
andypro1 Posted November 23, 2005 Report Share Posted November 23, 2005 cant be the bb its probaly the freewheel all the pawls will be nakard Quote Link to comment Share on other sites More sharing options...
bikerboysam1 Posted November 27, 2005 Report Share Posted November 27, 2005 i would have to agree with everyone else, its either your freewheel rounding out, or your bottom bracket Quote Link to comment Share on other sites More sharing options...
