Better Hs33s?
ogre
I've not had my bike long (2/3 weeks methinks) and the back tyre slips at anything, i couldn't even hop up a high curb without my tyre rollin back with a super ugly high squeal, i've tarred my rims and ordered a booster (onza carbon fibre) could someone recomend decent brake pads?
See the pad thred in trials chat.
I assume your still using the kool stops that came with the bike / magura. So anything will be better really.
I'm a big fan of the zoo pads. A little tar and zoo pads is the best setup i have tried.
Heatsink, koxx bloxx, zoo pads. All good pads.
Edited by JT!
what ever you do do not get the zoo pads they are too soft that pieces of your pad fall off every so often even on a smooth rim and dont argue with me just ask flower simp.
if your running a smooth rim then id have to say koxx bloxx pads or heatsink
if your running a grind then also i recommend koxx boxx or heatsinks
i also have a carbon booster and its great be aware though for the first few rides your pads will move and the mounts will be loose but after a couple of rides its great heat sinks on a grind (dead) and tar amazing mate :P
clean off all that tar from the rims and put a nice harsh grind on the rear rim accompanied by some heatsink blue pads, i've been running this for a while and never have any problems with the brake, the pad wear rate is also very good on a harsh grind
it also helps if the brake is set up well, you want to have the pads square to the rim so when the lever is pulled the pad makes full contact with the centre of the braking surface, this will reduce the spongy feel of the lever and make it work alot more effectively
if you need any help on grinding rims do a search for "grind" or "rims" etc and you'll find some decent info
Heatsink blue's are rubbish in the wet or damp weather :P go for koxx bloxx (brown) they are the best this time of year with the wet conditions they hold a lot better than crm's and any heatsink pads. Also get somone to grind your rim so theres no need to use tar :P
hope I helped :P
rickyb
Or looking at tartybikes the new echo pink and reds are pritty much the same as the zoo pads but with a slitly stronger compound so that would give you better ware rate on the pads but will decrease the grip power of the pads so they should be good on a grind :P And with the added pimpness of pink pads is always a good adition to your bike :P
but a review would be worth looking at before you buy the echo pads.
rickyb
I find that koxx browns are realy good especially on a grind. I try`d the zoo pads the other week on a realy soft grind and they are amazing to but they were gone in about two days. So i reckon your best bet is koxx browns on a good grind. :P
