Simpson Posted November 18, 2005 Report Share Posted November 18, 2005 Do smaller drops and learn to ride smoothly, there is a way that you lower the front end almost vertically then flick off on to your back wheel worth a try Quote Link to comment Share on other sites More sharing options...
Houseface Posted November 18, 2005 Report Share Posted November 18, 2005 :blink: just before you drop, let your front wheel down a bit, but not so much that you go front wheel first. steve Quote Link to comment Share on other sites More sharing options...
mackey Posted November 18, 2005 Report Share Posted November 18, 2005 firstly edge closer and closer to the edge of the drop on your back wheel then when you just reach the edge let your front wheel drop till it is almost vertical and give it a little kick to land on the back wheel and bend your legs to compress the landing start by dropping your front wheel at little stages at a time then you will get the hang of it but start small and work your way up :blink: Quote Link to comment Share on other sites More sharing options...
Simpson Posted November 18, 2005 Author Report Share Posted November 18, 2005 Could try adjusting trye pressures but sure its mostly your technique Quote Link to comment Share on other sites More sharing options...
Martin Grainger Posted November 19, 2005 Report Share Posted November 19, 2005 pissin_on_the_fence said: Could try adjusting trye pressures but sure its mostly your technique yes, i found the tyre pressures helped me land smoother and lowering the front makes there less to drop until you hit the ground. if you do lower the front remember not to pull the bike back up before droping because it makes the lowering of the front pointless. Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted November 19, 2005 Report Share Posted November 19, 2005 (edited) Picture of one of my drops today, Basically keep edging forward on the back wheel untill your at the edge of the drop then lower the front wheel a little & kick off, hopefully landing safely. :) Edited November 19, 2005 by SamMonty Quote Link to comment Share on other sites More sharing options...
joewhite Posted November 19, 2005 Report Share Posted November 19, 2005 hey Nice pic monty but hey lowering the front is a good way but im not very good at it so i tend just to drop and i have very little trouble with landing hard but i run severly low pressure you should give it a try joe Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted November 19, 2005 Report Share Posted November 19, 2005 pissin_on_the_fence said: Do smaller drops and learn to ride smoothly, there is a way that you lower the front end almost vertically then flick off on to your back wheel worth a try Don't you mean horisontally? or am I an idiot? Quote Link to comment Share on other sites More sharing options...
Da-bomb-boi Posted November 19, 2005 Report Share Posted November 19, 2005 ash-kennard said: Don't you mean horisontally? or am I an idiot? haha no i spotted that and was a little :- . anyway what i found helped although i still cat drop for poo, was to get on a kerb and see how low i can get the front end so i learn the technique of dropping the front without the risk of bailing. it also allows you to get rght to the edge as there is a deffinate edge...if that makes sense, either way after nearly 2 years of trying (my ghad ive only just realised :) ) im still poo. but good luck Quote Link to comment Share on other sites More sharing options...
miket-raptorman Posted November 19, 2005 Report Share Posted November 19, 2005 (edited) Yeah like 2 or 3 people said vertical what? did you miss High School! remember horizontal is flat vertical is straight up Too Drop off keep your weight low to your bike and right back, lower your front till your horizontal and pedal kick, your back wheel should hit the floor with your bike vertical and your body positioning should stop your front wheel from slapping down if it doesnt work your not doing it right but youll get it. i mean if i did any retard with a releigh can. Edited November 19, 2005 by miket-raptorman Quote Link to comment Share on other sites More sharing options...
Mc Lovin Posted November 19, 2005 Report Share Posted November 19, 2005 (edited) Start from scratch, Go back to dropping off cerbs and eventually get higher but instead of doing it how you used to do it just land on your back wheel then keep on hoping, It will teach you to crouch when you land on your back and absorb the shock more then when it comes to bigger drops you will be allot smoother and lower the front wheel slower. Edited November 19, 2005 by tom_wilko Quote Link to comment Share on other sites More sharing options...
