theone2be Posted November 17, 2005 Report Share Posted November 17, 2005 does any one know how to remove disc pads from a hydrallic dic brake as i dont wanna just pull them out as fluid may leak, (it may not i just dont know how to take them out and havent tried just in case) Quote Link to comment Share on other sites More sharing options...
miket-raptorman Posted November 17, 2005 Report Share Posted November 17, 2005 you seem to be doing alot of maintenance. good on you! Quote Link to comment Share on other sites More sharing options...
llandudno_trialsboy Posted November 17, 2005 Report Share Posted November 17, 2005 isnt there a split-pin or a bolt you can take. if there is take em out and they should just drop out. have a good look first. Quote Link to comment Share on other sites More sharing options...
theone2be Posted November 17, 2005 Author Report Share Posted November 17, 2005 click the link,, ok then which bolt(s) is it, and maybe someone can tell me what brake it is to disc pad removal Quote Link to comment Share on other sites More sharing options...
theone2be Posted November 17, 2005 Author Report Share Posted November 17, 2005 any ideas any one Quote Link to comment Share on other sites More sharing options...
Jonny Shoe Posted November 17, 2005 Report Share Posted November 17, 2005 No the hydraulic fluid will not leak out when you remove them, the fluid is only used to push the pads in not surround them. There should be a split pin on the outside of the caliper which will allow the pads to release, unfortunately they can be very tricky to get back in again. Hope this helps Quote Link to comment Share on other sites More sharing options...
mat hudson Posted November 17, 2005 Report Share Posted November 17, 2005 get some balls, tug em by the tags Quote Link to comment Share on other sites More sharing options...
ogre Posted November 17, 2005 Report Share Posted November 17, 2005 I've got cable so i don't know if they're to different but i normally just take ou the tyre, and jiggle them about a bit and they pop out quite easily Quote Link to comment Share on other sites More sharing options...
Rich J Posted November 18, 2005 Report Share Posted November 18, 2005 when i had to get mine out i just pulled because they were held in by magnets not sure if yours are but this might help Quote Link to comment Share on other sites More sharing options...
theone2be Posted November 18, 2005 Author Report Share Posted November 18, 2005 its ok i found out its a formula 100, and they were held in by two bolts. thanks for the help people Quote Link to comment Share on other sites More sharing options...
