Monty Booster
Yes i`m very sure monty do make a brake booster.But it is specialy made for monty frame`s so it`s no use if you don`t have a monty.Just ring cleanbikes up and ask them about it.
Cheers
Deonn
P.s the way you can check if you can run it is just have a look under where the rear brake mounts are.There should be a thread on either side to where the booster screws in. :(
They are just for the bottom two holes really.
Yep this guy is right they do make an under frame booster. I have one on my Hydra and it does work quite nicely, I would imagine a combo of these ones and a good quality back boosterm, RB, echo etc. would work magnificently.
They are only made specifically for Monty bikes. On Monty bikes there are 2 holes drilled into the frame from the underside of the frame where your brakes are bolted on. These boosters bolt into these holes instead of, as a conventional booster does, bolting onto the top of the rear brake.
Hope this helps.
