Onza T-pro The Best Setup
c.kezer
my dream bike will come true at crimbo i have a t pro with echo easy forks zoo riser bars and zoo stem
and im getting :tensile cranks hope mono trial disc brake red try all rims with front hope hub and rear try all :P (Y) cant wait
That's nearly the exact same as what he is getting for chrimbo (Y)
Anyway, mine would have to be
Frame : T-Pro
Forks : Echo Team 05
Bar & Stem : Monty
Front Wheel : American Classic, Echo
Rear Wheel : Chris King BMX, Echo
Chain : KMC Kool
Front Disk : Magura Marta, XT Lever
Rear Break : Magura, Koxx Bloxx, Rb Lever, Echo Team booster
Cranks : Tensile
Pedals : V8 - V12
(Y)
Mat
I have my dream setup, apart from my rear wheel.
My bike ATM:
Frame - T-pro 05
Forks - Monty X-lite 04
Front wheel - onza reggie on a Hope XC
Front brake - louise 05
Rear brake - Maggy 05 with (soon to be browns) ATM once plazmatic and one Heatsink blue (Y)
Chain - KMC
Tyres - CC (Y)
Rear wheel at the min - Onza hog rim on a T-pro standard hub
Rear wheel at crimbo - Echo 06 rim (black) built onto a T-master hub (Y)
Than my bike will be finally finished and hopfully WONT fook up!
Mine is set up as follows:
Frame: Onza T-Pro
Forks: Echo Easy Team
Cranks: Monty 221 X-lite With fixed cog
Front Rim: Echo CNC
Rear Rim: Echo CNC
Front Hub: 05 Echo
Rear Hub: Mini Cassette Profile
Bars: Monty riser
Stem: Monty 221 Ti Stem
Tires: Rear Maxxis: Front Echo
Pedals DMR V8's
Rid(es) like a dream, selling all the Bits off now to help do up my Pitbull.
If you set yours up to a similar set up it rides beutiful, i tried Zoo bars and it felt like a full on comp bike, so easy to throw around.
Cheers, Biff
would be nice if i could aford
Frame: Onza T-Pro 05
Forks: GU
Cranks: Tensile UCI - 18t ACS
Front Rim: Echo CNC
Rear Rim: Echo CNC (maybe) or Ronnie with a grind
Front Hub: 06 Echo
Rear Hub: 06 Echo Fixed
Bars: Zoo 06 riser
Stem: Echo Mod stem
Tires: Maxxis Creepy Crawlers
Pedals: Onza Hognesium
Grips: ODI lockons (with anodised claps)
bearings: Echo 06 head-set / BB
brakes: HS33 rear with plasmatics or Zoo (or Spanishfly/koxx browns on a grind)
Hope trials with anodised upgrade to match rims and bits
Goodridge braided hoses
black spokes and nipples
but i cant (Y)
