Drive Train Setup
theone2be
ok then, im gettin a 26" bike but it has no drive train, i want to get a middlesburn pro trials crank, and want to go single speed but what would your guys put in these spaces::
1. rear sprocket/ chassette :
2. pedals :
3. chain :
4. chain tensioner : (or should i take links out and keep it tensioned that way)
thanx
s
a
m
1. rear sprocket/ chassette : not sure
2. pedals : if afforded get the dmr v12's or I think the xp's ( i think that's the name) are popular
3. chain : kmc kool chain
4. chain tensioner : (or should i take links out and keep it tensioned that way) not sure
(Y) toby
Get a steel front ring (otherwise it will get munched pretty quick, stock middleburn ones are ally, but still wear quick)
Dmr v12s / v8's depending on budget. If your going to get welgo copies make sure you get the v12 copies, the v8 copies are rubbish.
Depeding what gear ratio you like, between 15 and 18 tooth cog on the back, i run a surly SS cog with old cassette spacers.
a fresh products tensioner is best, i have one and its great. Definately needed if you are running vertical dropouts.
1. rear sprocket/ chassette : DMR single speed kit
2. pedals : wellgo V8 copies (cheaper and just as grippy)
3. chain : KMC kool/KHE collapse
4. chain tensioner : fresh products tensioner
Thats what i run and its good :shifty:
The fresh products tensioner is LOADS better than the Surly i had
