MOSH Posted November 9, 2005 Report Share Posted November 9, 2005 Hi guys I have just received my 2006 Zoo python and echo headset (N) Problem is at the back (the end of the chainstays) there are two little bolts one either side ? what do they do ? as the one on the drive side rubs the outer shell of my king when it spins backwards ! I want to take them out but they must be there for a reason ! Any help would be good as I want to ride ASAP ! Havent ridin in over 3 weeks <_<:( Josh.. Quote Link to comment Share on other sites More sharing options...
RicH_87 Posted November 9, 2005 Report Share Posted November 9, 2005 sounds like they are just the bolts that snail cams use to adjust your wheel. You using snail cams or not? if not how are you tensioning you're chain? Quote Link to comment Share on other sites More sharing options...
modrider666 Posted November 9, 2005 Report Share Posted November 9, 2005 (edited) Hi there mate, I think the little bolts you are on about are the ones for snail cam chain tensioners. What chain tensioners are you running at the minuite. But they will be fine to take out if your not going to use snail cams. Thanks Peter Beat me to it^^ Edited November 9, 2005 by modrider666 Quote Link to comment Share on other sites More sharing options...
MOSH Posted November 9, 2005 Author Report Share Posted November 9, 2005 Cheers lads a mate just told me <_< how stupid hey it was the excitement ! Close topic before others see (N) josh Quote Link to comment Share on other sites More sharing options...
Houseface Posted November 9, 2005 Report Share Posted November 9, 2005 just a quick question(dont want to start a similar topic) can you get things to use snail cams or do they have to come on the bike? steve. Quote Link to comment Share on other sites More sharing options...
sir trial a lot Posted November 9, 2005 Report Share Posted November 9, 2005 they are just cap head bolts. i have 100s of stainless steel ones lying around. add me to msn in my sig if you need some :D Quote Link to comment Share on other sites More sharing options...
