What Am I Doing Wrong?
Greetings
ive started downloading it but im currently on dial up conection. while im waiting i would just say make sure you have a good angle when your front wheel is on the rail. if your going straight at it then your rear wheel has alot further to travel to get on the rail. just try to get your back wheel nice and high aswell so that you have plenty of time to push your rear wheel on to the rail. and by the way that is all tunnicliffe and cls seem to do all day every day so dont worry if it takes a while to learn. just practise and loads of effort to get your rear wheel on to it.
  BASETA26ER said:
i think you would have done it a couple of times but you had the pallets/creates in the middle if you didnt have them i think you would do it.. it would push you further too do it beacuse you will not want too fall off (Y)
Yeh but if there is a gap in the middle it is a lot harder to get the confidence to even try the gap incase you fall into the middle. Looks like your doing it fine, just practice. (Y)
