stubert Posted November 8, 2005 Report Share Posted November 8, 2005 (edited) Ill probably be able to work this out fine tomorrow, but just to save any confusion, im wondering what fitment will be like, dave from tarty did tell me but i forgot as had a lot going on in my head at that moment in time. Its a 73mm shell but has a spacer so it will fit a 68mm frame, does this spracer just butt up against the drive side cup? as it is in the piccie below? Any help appreciated, thanks RED LINE POINTS TO SPACER EDIT - Just reaslised that the red line is pointing to the NON-drive side, but do i still use that spacer for my 68mm frame? Edited November 8, 2005 by stubert Quote Link to comment Share on other sites More sharing options...
Mark W Posted November 8, 2005 Report Share Posted November 8, 2005 The red line's pointing to the drive-side, and you'll put that on the driveside to reduce it from 73mm to 68mm. If you've got a 73mm shell, don't put it on there. Simple as that (Y) Quote Link to comment Share on other sites More sharing options...
stubert Posted November 8, 2005 Author Report Share Posted November 8, 2005 royally messed up that post, mark helping me on msn as i type.......... Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted November 9, 2005 Report Share Posted November 9, 2005 Fit the BB as shown in the picture <_< Spacer on the drive side. Quote Link to comment Share on other sites More sharing options...
Waynio Posted November 9, 2005 Report Share Posted November 9, 2005 you literally couldnt fit the spacer to the non drive side............. on some frames you do need to use "2" of those spacers, but its quite limited to which frames, its some of the "messed up" taiwanese ones.the ones that arent quite straight. haha Waynio........................ Quote Link to comment Share on other sites More sharing options...
