random Posted November 5, 2005 Report Share Posted November 5, 2005 Had an issue with my drive side Magura mount, as i did the bolt up it rode up the frame thus putting the pad on the tyre...not good. So i used some spacer i made by splitting up an old chain. Plonked one on the bolt then fitted as normal. No more ridding up the frame, did this both top and bottol and it's done the job. Also my Chris King Axle has cracked all the way to the bearing coller thread...cos i can't be assed to send it away yet i ran a line of supergule that does bond metal to stop it going anymore. seams to of worked. So what other hint and tips of cunning bodgery you got?? Quote Link to comment Share on other sites More sharing options...
powerbikes Posted November 5, 2005 Report Share Posted November 5, 2005 (edited) my cuz got a puncher but had no paches so he glued the inertube then put the tyre on pumped it up so the tube stuck to the tyre (Y) good work Edited November 5, 2005 by powerbikes Quote Link to comment Share on other sites More sharing options...
