Adamant Or Czar
stevecoust
Don't worry about the Czar snapping. Despite it's looks it is NOT an XTP. I think the frame is at least a pound heavier in weight due to the heavier tubes used, I would expect it to last a while longer than your XTP anyway.
The Adamant frame does look nice though. I don't think durability should be an issue when choosing between the two. The main difference is looks since the geometries appear to be very close. If you liked the way your XTP looked pop for the Czar if you want a change go Adamant.
x Dani x
CZAR is made outta U6 which is stronger than the tinfoil that the xtp is made out of
The XTP is actually U6 as well - just the tubes are thinner, to save weight.
Like MrsMonkey (haha) says, theres not a lot between then - have a ride of Phils Czar and see what you think! I assure you the Adamant is also very sweet, looks nicer in real life in my opinion - the matt black finish is very classy.
