Going Wireless On An Ibook
zoojames
Just wondering if anybody is currently using apples wireless technology?
I'm planning on getting an iBook and want to run my internet on it (ntl broad band currently connected via USB) I havn't got a router or anything. What will I need (I know nearly nothing about wireless ics)
Thanks for your help with this guys :lol:
James (Y)
All new iBooks come with airport extreme as standard anyway. So you won't need to buy that, and you'll be able to get straight onto WiFi hotspots with your iBook.
Then you just need a router for your house. I assume your NTL modem has 2 connectors (I think they all do), so use an ethernet cable instead of the USB connection. And then you will need to buy a router - I use a Netgear WGR614 and it works fine, but there are plenty of other options. Shouldn't be more than £40 ish I think. You do not want a router with a modem built in, that won't work with NTL.
Nah, unplug the USB cable and throw it away. Then plug it in like this:
Ntl modem --> (WAN port) Router (LAN port) --> PC
Using all ethernet cables. You should have got at least one with your modem. Should be more obvious when you get the router :blink: I bought my router from eBay. If not then just have a look on internet computer shops eBuyer, Scan, Dabs, Aria, Microdirect etc.
