Brian Bleech Posted November 3, 2005 Report Share Posted November 3, 2005 just a quick question here. Is the only difference between the ronnie and reggie rim, the width? Mike Quote Link to comment Share on other sites More sharing options...
Trebor Posted November 3, 2005 Report Share Posted November 3, 2005 Ronnie is 38mm Reggie is 32mm There may be slight differences in the build of the rim (I'm sure Tarty could tell you) but essentially they seem like the same rim, as you said, in different widths. Quote Link to comment Share on other sites More sharing options...
Damon W Posted November 3, 2005 Report Share Posted November 3, 2005 Ronnie = 38mm rear doublewall rim Reggie=31mm front singlewall rim Quote Link to comment Share on other sites More sharing options...
Waynio Posted November 3, 2005 Report Share Posted November 3, 2005 i think they both have double wall construction as the hog is the single wall constructed rim :lol: i thort anyway. the difference is mike one buckles, and the other buckles when you look at it.........:D(Y) no there not too bad really. haha. there ok, but they need the side walls angling out a bit, instead of |-----| they need to be a bit like this \-------/ stops the rim denting :lol: Waynio....................... Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted November 3, 2005 Report Share Posted November 3, 2005 Also the ronnie has a larger braking surface. (Y) Quote Link to comment Share on other sites More sharing options...
Dan-Walker Posted November 3, 2005 Report Share Posted November 3, 2005 the onza hog rear rim is double wall constructed. Quote Link to comment Share on other sites More sharing options...
JT! Posted November 3, 2005 Report Share Posted November 3, 2005 Isn't one suposed to hold a grind better? Or an i in the land of the fairys? Quote Link to comment Share on other sites More sharing options...
tipsy Jock Posted November 3, 2005 Report Share Posted November 3, 2005 Isn't one suposed to hold a grind better? Or an i in the land of the fairys? The Ronnies better over the Hog, I think the ronnie and rennies are the same material Quote Link to comment Share on other sites More sharing options...
ScotchDave Posted November 3, 2005 Report Share Posted November 3, 2005 The Ronnies better over the Hog, I think the ronnie and rennies are the same material That they are, same material, grind well by all accounts. Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted November 3, 2005 Report Share Posted November 3, 2005 (edited) They are designed as a pair. Same material, eyelettes etc. Reggie is for the front 32 hole only. 32mm wide and 12mm high, double walled sidewalls. Ronnie for the rear, 32 or 36 hole. 38 mm wide 14mm ish high, double walled sidewalls. This is for MOD. not sure about stock/24'' Edited November 3, 2005 by Joe_Elding Quote Link to comment Share on other sites More sharing options...
fubarpatsharp Posted November 3, 2005 Report Share Posted November 3, 2005 i asked this question a while ago to the peeps at tartybikes they say Hi Stuart, Pretty much! The Reggie is a scaled down Ronnie basically - lighter, thinner, not as tall. Reggie recommended for front, Ronnie for rear. Cheers, Adam On 11/3/05, Stuart Sharp <fubarpatsharp@hotmail.com> wrote: > whats the different between the ronnie rim and the reggie??? > Is it only the width of the rim????? the reggie comes in 36h as well! Quote Link to comment Share on other sites More sharing options...
