Avid Juicy 7 Review
Siders77
Hey guys. I've had my Juicy 7 on the front of my mod for a while now so I thought I'd do a review. :D
I got this brake from CRC, it was in the sale for £109 which I thought was a good price. :P
Anywayyyyyyyyy....
As soon as I got this brake I fitted it and went out in my street for a little play. I was amazed at how much power it had straight out of the box. It didn't need bedding in or anything. The only thing I didn't like at first was that the lever came all the way into the bar, but I played with the TPA a little bit and it was fine.
It also has a Tri-Align caliper which means that you don't have to piss about with putting washers on to space out the caliper so it doesn't rub, which is nice. :D
Before the Juicy I used a Hope Mono Mini and couldn't stand it so I got rid of it with in about a week because it had no hold at all. When I put the Juicy on it felt a whole lot better because it had nice hold, nice modulation and also a nice lever feel.
I've used a few Hope Mono Trial brakes on peoples bikes and I can honestly say that my Avid is more powerful than all of the Hopes I've tried and no, it's not just because I have an Avid! :P
Good things about the brake....
  • It can be used as a front brake or a back brake.
  • The TPA can be taken out and screwed in on the other side if it's being used as a rear brake.
  • The pad biting point can be changed with the TPA.
  • The TPA looks uber strong because it's not like the Magura one, (Just a tiny threaded bit) it's a huge thread so it wont snap very easily.
  • The lever feels great.
  • It's VERY easy to set up and get working properly.
  • Is fairly cheap compaired to other disc brakes out there.
  • Locks nicely.
  • Has nice modulation.
Bad things about the brake...
  • The rotor bolts on with Torx bolts so you have to carry around a Torx tool just incase the rotor bolts come lose.
  • The brake overheats quite easily. (I'm not sure if that's because I have a Hope rotor on there?)
I guess that's it.
Go out and buy one of these brakes! :D
