A Bob Rim Laced To A Mono....
Urpedigreechumdog
Spoke lengths can be a bit difficult, but can be sorted easily using the advanced spoke calculater, simply do it one side at a time (Left hand side = non drive side of the hub ) and where it says rim offset, just put in (in mm obviously, half the width of the rim that it's being laced to), and it will take the offset into account. Or, if that's a bit too complicated for you, I'm sure if you're buying the spokes from tartybikes.co.uk, Adam will be happy to help.
When in doubt, leech off fatmike :D :P
Why? so i get an answer of 'erm i dunno, sorry mate'.
I was tired + busy. :P
What Edd quoted is all you need to work it out, since I wasn't very helpful the other evening, I'll help a little more now.
http://www.sheldonbrown.com/rinard/spocalc.xls
Get that.
Enter the hub measurements. (Easy to find, should be in the spreadsheet)
Enter the ERD of a mavic X517 (It's in the spreadsheet :D)
Then, (like Edd correctly quoted) under offset spoke bed, enter -11mm. Just realising now, looking back at my post that I forgot to mention it is a minus, as you'll want the spokes to cross over (like a sand timer), not for them to not cross over, (like a trapezium). :D
You should be sorted with that. :P
Mike.
This topic is now closed to further replies.
