Different Places To Mount Brakes!
ollie
Std mounting - thats on top of the stays, seatstays.
^ why---well my little friend, look at how the wheel turnss and the direction it does. When you lock up the back brake look where that laod on the brake has gotta go > yeah to the right as it be. So they stic em on top and then when you lock the brake up the force gos through the moutns and down the seat stay tubes.
if they did them below, like some U brakes it's not gonna be as stiff and really flexy.
Leeson one did a P3 frame one off with them mounted on the top of the Chainstays, thus worked the same as the normal manner for seatstays but they beeffed up the chainsatys a bit (thicker) and the fact there so close to a very soild object being the Bb shell as to the normal manner of a toptube which that are has loads of flex as to the bb unit. It was uber stiff but rim width your limted on unless you have uber wide BB's
Discs, well top ripp off in trials
Inbetween you got ether 2 or 3 ancor points, being seat and chainsatys or seat and chainsatys and dropouts (leeson)
