Drilled Rims
scott13
At the moment, tartybikes have special offers on echo CNCed rims for only 45 pounds for the pair!! If they aren't your taste and actually want proper drilled rims then try viz rims (about 35 posted from vizbikes) or try-all rims. Another option could be the doodey onza ronnie rims (with hedgehogs) you can pick these up from tartybikes quite cheaply and they'll also build the rims up if you wanted!
Jackery (Y)
Edited by Teaming
