moo Posted October 23, 2005 Report Share Posted October 23, 2005 this may sound a stupid question but whats best to use to get a good grind on a rim, and is it really worth doin. Quote Link to comment Share on other sites More sharing options...
Connor Posted October 23, 2005 Report Share Posted October 23, 2005 1. use a stone cutting disc. 2 go round the rim once and then back the oppesite way. And the steeper you hold the angle grinder the harsher it will be, also if youve done it right there should be triangle shapes on the rim. Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted October 23, 2005 Report Share Posted October 23, 2005 1. use a stone cutting disc. 2 go round the rim once and then back the oppesite way. And the steeper you hold the angle grinder the harsher it will be, also if youve done it right there should be triangle shapes on the rim. what does that do? Quote Link to comment Share on other sites More sharing options...
moo Posted October 23, 2005 Author Report Share Posted October 23, 2005 ahh right so my angle grinder will be fine Quote Link to comment Share on other sites More sharing options...
mafu26 Posted October 23, 2005 Report Share Posted October 23, 2005 duno if this is common sense but hold the grinder at 90 degree to the rim aswell. i like having a grind, more consistant than having tar and it helps you out in the wet. eats up pads though. good luck! Quote Link to comment Share on other sites More sharing options...
moo Posted October 23, 2005 Author Report Share Posted October 23, 2005 cheers dudes :lol: Quote Link to comment Share on other sites More sharing options...
