<trialsking> Posted October 20, 2005 Report Share Posted October 20, 2005 right i always end up getting an ACS claw everytime my free wheel brakes and the back plate always unscrews itself asnd bearings fall out. does anyone else have this problem and what can ido apart from state the obvious ,. stop getting an acs claw. I heard eno freewheels were almost unbreakable but there like 60 quid?!! can anyone help cheers jamie :P Quote Link to comment Share on other sites More sharing options...
emery Posted October 20, 2005 Report Share Posted October 20, 2005 Hi to stop it coming undone simply undo the back plate then put some superglue or loctite on the screw it back on .. in england there about £80 but if you order from usa they cost about £50 toby :P Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted October 20, 2005 Report Share Posted October 20, 2005 right i always end up getting an ACS claw everytime my free wheel brakes and the back plate always unscrews itself asnd bearings fall out. does anyone else have this problem and what can ido apart from state the obvious ,. stop getting an acs claw. I heard eno freewheels were almost unbreakable but there like 60 quid?!! can anyone help cheers jamie :P Tried loads of makes, ACS claws seem to last not to bad for the money. Keep spraying WD in it regular & you will find it will last loads longer. :P White industries are suppose to be one of the best but you can get several ACS for that sort of money. :P Quote Link to comment Share on other sites More sharing options...
wardie Posted October 20, 2005 Report Share Posted October 20, 2005 ENO's are supposed to be the best but you could buy a welded shut acs http://selectbikes.com/shop/description.php?prodid=58 sam Quote Link to comment Share on other sites More sharing options...
Charlie - CTT Posted October 20, 2005 Report Share Posted October 20, 2005 speek to dan ko from viz bikes trials-uk wat eva it is. and ask him 4 1 of the acs claws that he gets. the lock ring has been welded on them and ground down so they look nice. lockring dont come off hay presto. i have tried it with lock tight and it didnt work.. it undone lost me bearings and no more ridr for about a week.... hope fully my acs from ko should b here 2 moz so if u wana i put up a lil review in a couple of weeks but yeah i would say viz acs £15 or a monty acs £35 both does the same and got the same internals but the viz 1 is better for the money. personaly i dont like eno freeweeels either. had 1 skipt waaaaaaaay 2 much... at least 5 a day. so i accidently :P got my bruv to break it and get me a new monty 1 :P hope this helped. probably didnt cus no one can understand me typing like Quote Link to comment Share on other sites More sharing options...
sembo_trials Posted October 21, 2005 Report Share Posted October 21, 2005 right i always end up getting an ACS claw everytime my free wheel brakes and the back plate always unscrews itself asnd bearings fall out. does anyone else have this problem and what can ido apart from state the obvious ,. stop getting an acs claw. I heard eno freewheels were almost unbreakable but there like 60 quid?!! can anyone help cheers jamie (Y) whiy industries!!!! right i always end up getting an ACS claw everytime my free wheel brakes and the back plate always unscrews itself asnd bearings fall out. does anyone else have this problem and what can ido apart from state the obvious ,. stop getting an acs claw. I heard eno freewheels were almost unbreakable but there like 60 quid?!! can anyone help cheers jamie (Y) white industries-my mates has one and it aint done owt wrong yet!!he boughtnit from airevaleycycles.com Quote Link to comment Share on other sites More sharing options...
T-BAD Posted October 21, 2005 Report Share Posted October 21, 2005 whiy industries!!!! white industries-my mates has one and it aint done owt wrong yet!!he boughtnit from airevaleycycles.com yeh white industrys (the way forwards) (Y) (Y) Quote Link to comment Share on other sites More sharing options...
kick-this Posted October 21, 2005 Report Share Posted October 21, 2005 "Weld" or buy a "welded" Acs £15 sorted (Y) Quote Link to comment Share on other sites More sharing options...
Waynio Posted October 21, 2005 Report Share Posted October 21, 2005 white industries deffo!!!! i used one last weekend at the cycle show in london on the levelboss mod i borrowed off ben savage and it was the mutts, didnt slip once over the weekend and it has a bit of pasty going through it too....... buy cheap buy twice as the old saying goes................. if you buy somthing good its going to last, how i look at it anyways. ENO are the way forward for front freewheel. Waynio...................... Quote Link to comment Share on other sites More sharing options...
Martin Posted October 22, 2005 Report Share Posted October 22, 2005 yeah, enos are supposed to be as good as chris kings? Quote Link to comment Share on other sites More sharing options...
Houseface Posted October 22, 2005 Report Share Posted October 22, 2005 go for the acs claw(welded) if you have a small budget but if you have aenough go for the eno white industries one steve. :lol: Quote Link to comment Share on other sites More sharing options...
Mat Smith! Posted October 22, 2005 Report Share Posted October 22, 2005 Go for an ENO if you can afford, but if you’re a bit tight on the money just get an ACS, and get it welded if it keeps coming loose Mat Quote Link to comment Share on other sites More sharing options...
cvtrial Posted October 22, 2005 Report Share Posted October 22, 2005 White industries is definately the best, but I'm using ACS myself! I can't tell you anything that's bad with that freewheel but White industries has many more engagement points so it's a lot better! Quote Link to comment Share on other sites More sharing options...
JT! Posted October 22, 2005 Report Share Posted October 22, 2005 Keep spraying WD in it regular & you will find it will last loads longer. Dunno about that (Y) Mine eno's fine. It's lasted comming up to a years and i have now had to replace the pawls. So basicly they don't brake, things just get worn down as you could expect, as ACS caluse's usualy brake befor it gets to that point. With an acs cluse thought, a little bit of glue on the threds will do they job if you can't afford one. Quote Link to comment Share on other sites More sharing options...
BASETA26ER Posted October 22, 2005 Report Share Posted October 22, 2005 enos are the best but too be fair acs claws are fine for trials with a bit of weld around the lockring! Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted November 22, 2005 Report Share Posted November 22, 2005 Fed up with my freewheels not lasting more than 2 weeks, are these white industries worth the money. My local bike shop has one in the cabinet priced at £86. :P Would like to hear from someone who has used one for a good while. Cheer's Sam. :P Quote Link to comment Share on other sites More sharing options...
aff1e Posted November 22, 2005 Report Share Posted November 22, 2005 hi mine done the same thing,i got my dad to put 2 welds on the bit than comes loose and it doest any more :P n i have had it on my onza for 3 months and its fine now hope this helps tom :P Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted November 22, 2005 Report Share Posted November 22, 2005 Thanks Tom, Have tryed welds but i can split the outer of a freewheel in 2 quite easily. Really looking for someone with the white industries. :P Cheer's Sam. Quote Link to comment Share on other sites More sharing options...
Barbara Logan-Price Posted November 22, 2005 Report Share Posted November 22, 2005 (edited) yo sam ive been running eno for bout 1 week and a half it hasnt skipped once and is really nice to ride with you should get one :P~ ps:and get msn sorted :P Edited November 22, 2005 by alex!beastytrials Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted November 22, 2005 Report Share Posted November 22, 2005 Hi Alex, were did you get it from mate & how much, :P Quote Link to comment Share on other sites More sharing options...
Barbara Logan-Price Posted November 22, 2005 Report Share Posted November 22, 2005 i got it off me bro :P £30 order one from danko :P i think he does em for £75 ish :P Quote Link to comment Share on other sites More sharing options...
mat hudson Posted November 22, 2005 Report Share Posted November 22, 2005 imo eno's are better than kings. cheaper, lighter and i dont think marks has skipped since he removed all the thick gungy grease. kings seam to skip alot :P Quote Link to comment Share on other sites More sharing options...
Trials_joe Posted November 22, 2005 Report Share Posted November 22, 2005 I have seen them on ebay! The White industries one. Link: http://cgi.ebay.co.uk/white-industries-fre...1QQcmdZViewItem Quote Link to comment Share on other sites More sharing options...
Sam Oliver Posted November 22, 2005 Report Share Posted November 22, 2005 I have seen them on ebay! The White industries one. Link: http://cgi.ebay.co.uk/white-industries-fre...1QQcmdZViewItem Thanks for link Joe :P Quote Link to comment Share on other sites More sharing options...
BASETA26ER Posted November 22, 2005 Report Share Posted November 22, 2005 Fed up with my freewheels not lasting more than 2 weeks, are these white industries worth the money. My local bike shop has one in the cabinet priced at £86. :P Would like to hear from someone who has used one for a good while. Cheer's Sam. :P I have seen them on ebay! The White industries one. Link: http://cgi.ebay.co.uk/white-industries-fre...1QQcmdZViewItem there's afew on ebay.. Quote Link to comment Share on other sites More sharing options...
