Todge Posted October 20, 2005 Report Share Posted October 20, 2005 My profile hub has just decided to split in two? Is this frequent? Not had much luck with hubs recently ^_^ If anyone has the profile phone number/email at hand, could that please jot it down here. Thanks Quote Link to comment Share on other sites More sharing options...
Siders77 Posted October 20, 2005 Report Share Posted October 20, 2005 Phone number; +44 (0) 23 8045 8328 ^_^ Quote Link to comment Share on other sites More sharing options...
Joe Papasnap Maher Posted October 20, 2005 Report Share Posted October 20, 2005 Profile Racing Europe PO BOX 257 Sarisbury England SO31 4WE Tel:-02380458328 Quote Link to comment Share on other sites More sharing options...
mat hudson Posted October 20, 2005 Report Share Posted October 20, 2005 bluddy hell, how did that happen?? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 20, 2005 Report Share Posted October 20, 2005 Is this frequent? Not on hubs which aren't modified from 110mm spaced axle to 135mm spaced... Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 20, 2005 Report Share Posted October 20, 2005 Not on hubs which aren't modified from 110mm spaced axle to 135mm spaced... I was about to say that, surely you can't be too surprised that it's turned out like that, Todge? Quote Link to comment Share on other sites More sharing options...
Todge Posted October 20, 2005 Author Report Share Posted October 20, 2005 Do you seriously think that makes that much of a difference though? Quote Link to comment Share on other sites More sharing options...
CurtisRider Posted October 20, 2005 Report Share Posted October 20, 2005 surely his modification would place more stress on the axle rather than the shell? Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 20, 2005 Report Share Posted October 20, 2005 Do you seriously think that makes that much of a difference though? I'm not sure, but the extra flex can't be a good thing. Theres a fair bit more moment on that part of the hub when extending tha axle. What grade of alloy did you use for the axle? The Profile guys are away til Monday at Backyard Jam btw :P Quote Link to comment Share on other sites More sharing options...
Todge Posted October 20, 2005 Author Report Share Posted October 20, 2005 It has no axle as such, just those super duper long steel bolts either end. I cant see as that makes a difference as they are so long. Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 20, 2005 Report Share Posted October 20, 2005 Well the bolts screw into the axle around 25mm each end when using a 110mm spaced frame... so theyre gonna support the axle a lot. Quote Link to comment Share on other sites More sharing options...
Joe Papasnap Maher Posted October 20, 2005 Report Share Posted October 20, 2005 Do you seriously think that makes that much of a difference though? by the looks of it todge..yes :P Quote Link to comment Share on other sites More sharing options...
dave33 Posted October 20, 2005 Report Share Posted October 20, 2005 i expect its because their is loads more stress on the hub shell because you have build it to a mtb rim, not the longer axle, the fact that the axels longer will allow it to flex more than a shoter axle :P Quote Link to comment Share on other sites More sharing options...
hulltrialser Posted October 25, 2005 Report Share Posted October 25, 2005 just checked my profile after i heard a creak and mines cracked there too :- Ben Quote Link to comment Share on other sites More sharing options...
SQuiT-man Posted October 25, 2005 Report Share Posted October 25, 2005 Thatll be the cue for everybody to go out and check their profile hubs now. I would have thought Todge's would be down to two reasons- building a stock rim onto the hub would put a lot more stress onto it because of the leverage of the forces being further out- it should aso experience more force than a regular stock hub, too, because the flanges would be closer together..? Also, with less of the heavy duty bolts screwed into each end, and a wider with, theres gunna be more flex put through the hub shell. Weird that hulltrialser's profile has busted in the same way though, I take it you were running it on a mod? Hadnt heard of any breaking like that Quote Link to comment Share on other sites More sharing options...
Mr Motivator Posted October 25, 2005 Report Share Posted October 25, 2005 T-F word up: Profile hubs are shit. Quote Link to comment Share on other sites More sharing options...
Todge Posted October 25, 2005 Author Report Share Posted October 25, 2005 Wey hey :- I have started a trend B) Quote Link to comment Share on other sites More sharing options...
hulltrialser Posted October 25, 2005 Report Share Posted October 25, 2005 Todge what did profile say or havent you contacted them yet? Ben Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted October 25, 2005 Report Share Posted October 25, 2005 ouch, that looks gnasty :- , unlucky B) looks like im wont be having that problem as my profile arrives thursday with a brand new hubshell B) Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 26, 2005 Report Share Posted October 26, 2005 T-F word up: Profile hubs are shit. Sam word up: No? The BMX ones dominate in every sense. Quote Link to comment Share on other sites More sharing options...
Trebor Posted October 26, 2005 Report Share Posted October 26, 2005 Sam word up: No? The BMX ones dominate in every sense. He was kidding, Mark. Stating the trend, albeit quite old, that if something breaks it is therefore shite. Quote Link to comment Share on other sites More sharing options...
Shaun H Posted October 27, 2005 Report Share Posted October 27, 2005 Could try warranty but surely they're not gunna like it if you've spaced it out to 135mm? But I suppose they don't actually have to find out :) (Y) Unlucky Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 27, 2005 Report Share Posted October 27, 2005 He was kidding, Mark. Stating the trend, albeit quite old, that if something breaks it is therefore shite. If I was going to be Naughty Mod, I could make it look like none of this ever happened (Y) Nah, I didn't know how to take Sam's post. Pity posts aren't like men. I always know how to take them :) Quote Link to comment Share on other sites More sharing options...
