Sponge
Like I said to you, you WILL need new internal spacers, otherwise it'll f**k up again. Getting it araldtited in a pretty much 'freestanding' (in that it won't properly be tight against the spacers) probably won't last for long.
Have you tried your LBS? Seems quite a few freewheels use similar sorta spacers, 'cos when my ACS 14t did this, I ended up just using some random ones from a Dicta 14t...
