Plazmatic Alu Discs
lukebarryevans
alu rotors wear down fast and cost a lot and also the pads wear rate is bad aswell. Just stick with stainless steel rotor's and the pads made fro ss rotor's.Or if you want more power just upgrade rotor size and purchase a adaptor to go with.I have just been told in the past that alu disks aint worth it.hope this helps a bit
clarky :) ^_^
