Rear Mechs
Fishy
if you have a really dodgy chain line the chain can jump when back pedaling,
the chain should be parallel to the front chain ring, this isn't always possible if you run gears so set up your bike so your fave gear runs strait. the only way to do this is to either spacer out/in the cassette or change bb length, bb length is the way to go but it can be expensive
the chain can also skip if you have a stiff link - it may not be apparent when you pedal as if the link isn't to stiff but when you back pedal there is no pressure on the chain so its free to do what it wants. to fix a stiff link flex the chain by hand on every link (bend it back and for in the direction its not supposed to bend) this will free it up
also check there isn't anything stuck in your derailleur and that it is strait and not bent - move the chain line into its optimum position to check this
hope that helps
