Reliable Front Discs
flipkickbs
Sorry dont quite follow So the brake slips when the front wheel has weight on it when not quite fully on the edge of a ledge etc.?
No not just on a edge. The thing where you have your front wheel over the top of an object, for example a wall with a lip at the top. So you have your front wheel over the top of this lip and your hanging off your front wheel basically vertically.
http://www.trials-forum.co.uk/forum/index....md=si&img=11717
When there is not really much lip at all then the brake can slip backwards and down.
203mm ^_^
Avids are all good. I wasn't super impressed with the modulation of mine at first, but I bedded it in, and it's perfect now, pretty much. Just holds *so* well, it's crazy. Just having such great lock and hold (and modulation) in the wet is great...
now that is where it is at. i have a 203 with sram 5 lever and some cheap cable that is well greased and it is silly powerful.
i hate to say it but im scared of it lol
just go for the avid mate lots of hold and when you are used to it you can use the modultion to great effect
Edited by ian
when my hope mono trial works its awesome, i am having some problems with it at the moment but they are getting sorted.
i think i am going to replace the rotor with an aztec one or what ever they are. i know pedrosa (jix) has done it and he said it made it better, has anyone else done it, and has it made it better? cause the rotors you get with them are right crap in my opinion.
Try some silicone spray James - the grease won't work its way in properly. A new set of pads would do it good too ^_^
The Aztec rotors are pretty sweet, although I think it causes the brake to overheat and pads to glaze more easily. Theres less surface area, and the lack of holes doenst scrape the pads as well. When Kev's brake overheat and he hit that car, he was using an Aztec rotor I believe...
I like my magura marta sl, it works just as good as hope mono trials brakes but it's bit more expensive.
Also i rate avid cable disk brakes because there cheap and really sharp work well but the hope and magura have good modulation.
Cheers Kyle.
hope gothic :) - he was practically downhilling on a vinco, he likes to go fast - before then riding 'normal' trials it was absolutely fine and the brake worked awesome.
Everyone says the more expensive levers make it better but ime really happy with the one i have and its only about £10 .
But from the one you have i would change it; yours is a little sketchy ^_^ .
Just grab a not to expensive avid one from CRC.
Sam
Edited by samthebiker
Mine's a standard Avid rotor, basically. Just the one that came with it, to the best of my knowledge.
Apparently, those EBC red pads are made so that they dissipate heat better? Says they're more suitable for DH 'cos they don't overheat as much anyway, so they'd probably be OK for trials?
Was tempted to get the Aztec rotor when I saw it in a shop near here, but for £30 I couldn't be arsed, really. My 203 on there now is plenty good enough, and it's *awesome* for modulation now too ^_^
i really wonder how so many people can afford magura brakes..honestly. These blokes are going "GET MAGURAS" right off. Or hell, even HOPE's.
I get base wage.
I think the first statement is in part due to the fact that many riders here are <18 and don't have to pay rent!
Avid BB7 Mechanical. Get the Red Pads for it.
You'll save money. You'll be a better braker. It'll do the same exact job as a £200 brake.
I get base wage.
no-one i know buys maguras brand new for full price. most peeps get them 'free' with their first full build or get them of a mate/forum second hand.
you'd have to be desperate or stupid to pay full whack for a maggie.
I get base wage.
I'm 18, but I work two jobs (one at £5.05 per hour, which is pretty good compared to minimum wage, and one at minimum wage) to afford stuff ^_^
But yeah, true about the Maguras can't believe how expensive they are. I guess you do get good customer support/warranty with it though? But still, say, £190 for a new Marta is pretty intense.
The only problem I've got with my Avid is that if I'm slowing down from speed with it, it makes a really loud moaning sound? Not squealing, just loud... It's odd. Then when you let go of the lever, it makes a "Ching" sound as though you've flicked the rotor.
Weird.
Ah well, hoping it'll resolve itself. Only happens every now nad again...
Is the spring in correctly? I had that when my spring had popped out a bit and was catching the rotor...
Ok, i've come to the decision to go for the avid bb7 due to price and simplicity. I have also been looking at the avid sd3 lever to go with it, would this be a good enough lever or would it feel like poo? i've heard that different cables are better than others to reduce cable stretch and give a more solid feel? Would it be worth splashing out a bit on some new cable too? cheers for the input so far :P :P
