Hub Problems
stevecoust
is your cassete held togethor with pins or have you put each ring on seperatley? if they are on seperatly the do tend to dig into your freehub. with the pins in it spreads the pressure out between all the rings instead of the one you atre using to gap jump etc.
i had the same problem mate so i put a light film of oil or grease on the free hub body (i cant remember wich was best )it helped loads but the best thing to do is get a steel freehub body and make sure the cassete is on correctly and tight >_<
