How Do These Work?
Thom
Was browsing through thetrialsinshop.com and found this:
Jagwire barrel adjuster shifter - Do you want to get rid of that heavy shifter on your bar or seattube? These tiny barrel adjusters work great and mount almost anywhere
I've always wanted to get rid of my shifter but I wanted to keep my gears, so does this give me a full range of gears? and how do they work ?
Any help would be splendid !!
you owuld probably only get 2 or 3 gears out of it, not the full range as a barrel adjuster doesnt pull a lot of cable. good if you have a two speed set up with a trials gear and a getting around gear.
so if I have a 8 speed cassette and use the 19T for trials and 13T for a getting around gear, can this be adjusted to switch between those two gears ? or do I have to have two individual rings ?
