Tpa On A Hs33 (05)
T-BAD
take the lever blade off and wind the tpa ( use a screw driver if its to stiff ) to its full untill the metal plunger thing falls out and then greese it up and the red adjuster as well. put it back together and it should be alot freer. hope it helps
