The Simple Question
tom tom
My last grind has lasted about 2 weeks max on a Try-All rim. It wasn't a half-arsed grind either, it's just worn perfectly smooth (Y)
i find if you grind it atleast 12 times VERY rough each time, then your grind starts to hold for a long time, but then it f**ks your rim up big time
I have started using a ground rim since just before summer. I can say that it is well worth doing, especially for winter. I have tried both hard and soft compund pads on ground rims and they all work well (went from zoo pads to koxx browns, then to heatsink blue pads). Although pad wear rate is slightly faster the performance is much better. :$
And if your on a budget dig out your old magura black pads from the bottom of your tool box they work good on grinds :ermm:
For about a week until theres no pad left :$
Just postpones the inevitable purchase of new pads, i wouldn't bother running a grind if your not going to buy harder pads
