emery Posted October 14, 2005 Report Share Posted October 14, 2005 As the acs welded freewheels are out of stock would I be able to weld it myself . toby Quote Link to comment Share on other sites More sharing options...
N.Wood Posted October 14, 2005 Report Share Posted October 14, 2005 If you can weld and have a welding kit, then yes :ermm: *Cough* ???????? *cough* Quote Link to comment Share on other sites More sharing options...
Martin Posted October 14, 2005 Report Share Posted October 14, 2005 if you cant weld then try and find a local(ish) welder/metal worker and ask if they could do it. Quote Link to comment Share on other sites More sharing options...
Ash-Kennard Posted October 14, 2005 Report Share Posted October 14, 2005 Don't bother just do it up now and again. Quote Link to comment Share on other sites More sharing options...
aff1e Posted October 14, 2005 Report Share Posted October 14, 2005 ive welded my acs and its fine now, never comes loose just tack each side and it will new come undone again :ermm: Quote Link to comment Share on other sites More sharing options...
wilky_mod_legend2 Posted October 14, 2005 Report Share Posted October 14, 2005 to be honest i wouldnt bother but if i was you, and you wanted to get it done get its done professionaly :ermm: Quote Link to comment Share on other sites More sharing options...
moo Posted October 14, 2005 Report Share Posted October 14, 2005 i could weld it for you Quote Link to comment Share on other sites More sharing options...
emery Posted October 14, 2005 Author Report Share Posted October 14, 2005 thanks I want do it myself I'm going to wait till there in stock. toby :ermm: Quote Link to comment Share on other sites More sharing options...
nb88 Posted October 14, 2005 Report Share Posted October 14, 2005 Using threadlock (loctite) works the same, and means you can service the freewheel aswell. Do that :ermm: Quote Link to comment Share on other sites More sharing options...
Will Arnold Posted October 14, 2005 Report Share Posted October 14, 2005 Using threadlock (loctite) works the same, and means you can service the freewheel aswell. Do that :ermm: yer, or wack some araldite on the threads once it is together(couple of blobs of the stuff does it :- ) then, when it needs to be serviced, just wack it in some hot water. ta WIll Quote Link to comment Share on other sites More sharing options...
