Chris Cook Posted October 11, 2005 Report Share Posted October 11, 2005 (edited) Right recently i have got and echo rim on hope XC hub. I recently also had trubble with my bb coming loose all the time but i have tightened it up proper tight now and it has not come loose for a long time but i can hear a swishing sound in it so i think it needs greesing or its recked. ANd now to the point: Every time i tighten my rear wheel with the QR it pulls the frame or the wheel to which ever side the flappy bit is on the QR. And i try to spin my cranks backwards and they dont spin i can pedal fine but they are really tight. I am wondering what is wrong with it as it ios starting to piss me of! Is it the BB? Is it the QR? Is it the Hub? Please someone HELP ! ! ! Chris (Y) Edited October 12, 2005 by cooke Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 11, 2005 Report Share Posted October 11, 2005 How tight is your chain? Oh, and is it the Hope QR? Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted October 11, 2005 Author Report Share Posted October 11, 2005 The chain is not even tight is is just right and the QR is a shinamo one. (Y) Quote Link to comment Share on other sites More sharing options...
Mark W Posted October 11, 2005 Report Share Posted October 11, 2005 Is the hub axle itself OK? Not the QR, but the actual hub? And does the freehub body sound OK? Quote Link to comment Share on other sites More sharing options...
Lawnmowerman Posted October 11, 2005 Report Share Posted October 11, 2005 When you tighten your wheel push down on the frame and make sure its straight in the dropout. If its still doing it your frame may be bent (Y) Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted October 12, 2005 Author Report Share Posted October 12, 2005 Is the hub axle itself OK? Not the QR, but the actual hub? And does the freehub body sound OK? Well it seems ok. The freehub sounds ok. I was told by my mate that it could be that the hub freehub is to short. Like i should have 8 speed not 7 ? (Y) :P Quote Link to comment Share on other sites More sharing options...
shovel Posted October 12, 2005 Report Share Posted October 12, 2005 firstly make sure that when you tighten the qr you have one hand pushing down on the frame to hold the dropouts in place, if when you pedal back it is stiff and the chain kina sucks down above the chainstay then its the freehub, you say the rear hub is new? all hope hub come with a really thick grease which causes this when new, to get rid of this stickyness go out for long rides not doing trials but more sort of xc with alot of freewheeling this gives the grease a chance to loosen off and for the freehub to wear in a bit Quote Link to comment Share on other sites More sharing options...
Chris Cook Posted October 12, 2005 Author Report Share Posted October 12, 2005 firstly make sure that when you tighten the qr you have one hand pushing down on the frame to hold the dropouts in place, if when you pedal back it is stiff and the chain kina sucks down above the chainstay then its the freehub, you say the rear hub is new? all hope hub come with a really thick grease which causes this when new, to get rid of this stickyness go out for long rides not doing trials but more sort of xc with alot of freewheeling this gives the grease a chance to loosen off and for the freehub to wear in a bit Yea the chain like sucks a bit! Well the hub was 2nd hand of pauloliver on here. I am of top my LBS now so i will check with them. Quote Link to comment Share on other sites More sharing options...
