Two Brake Boosters
Zoo_Monkey
Some poeple have a frame with a built in booster, like the echo teams, and have a booster. But there's no real point of having two boosters. Might aswell just buy one good one.
i know - i have just found myself with 2 identical RB designs Boosters - one of whichis on my zoo - se sig. as the zoo is notorious for braking where the mags flex the frame i thort i could put bothe on to giveit extra strength
2 FRAMES! hardly notorious is it! just run 1 booster. like the echo team or an Rb
It's been done mainly with STD MAGURA ones for the evo system. You can mod a EVO booster to fit the top 2 bolts of a 4 bolt system.
You indeed can run 2 RB if you wish on you Zoo. You'll need longer bolts and some spacers. Use an old chain, split up and use the rollers as spacers. they fit the M4 bolts perfectly mate.
The reason Zoo crack there is the frame weak there, metal fatige, over wleding/heat and well nothing to do with a booster cos if anyhting that just allows it to be pulled directly off now!
