Swize Posted October 9, 2005 Report Share Posted October 9, 2005 Righty ho, I tryed some monty snail cams for my 04 T-pro and they proved way to small also the bolt would not fit through the hole next to the dropouts anyone else had this problem is it one of is it just because they where monty cams ? So I am looking to buy some Fresh Product Snail cams does anyone else have thease or any snail cams on T-Pro's? Cheers Sam Quote Link to comment Share on other sites More sharing options...
Dai the Socket Posted October 9, 2005 Report Share Posted October 9, 2005 Haven't got a T-Pro, but on my Python these are the dog's bollocks. They're f**king awesome. Well machined, perfect tension, look ace, uber light and work perfectly. I was going to post a topic about how happy I am with them to be honest! (Y) Quote Link to comment Share on other sites More sharing options...
SamHolmes Posted October 9, 2005 Report Share Posted October 9, 2005 Yep I run some on a python and they are the best cams Ive used My old cams kept slipping and making my chain slack, but my chains got the pefect tenison now and has been like it for over a month (Y) Quote Link to comment Share on other sites More sharing options...
Swize Posted October 9, 2005 Author Report Share Posted October 9, 2005 Cheers for thoes, really looking foward to them if they will fit. So no one knows about my problems with the t-pro (Y) Quote Link to comment Share on other sites More sharing options...
mr ailsbury Posted October 10, 2005 Report Share Posted October 10, 2005 MY mate used monty snail tensioner things on his T-Pro and they workd ok but one of them snapped in half when he was riding (Y) I use try-all snail tensioners on my T-Pro and they work very well :P ToM Quote Link to comment Share on other sites More sharing options...
Heatsink Posted October 10, 2005 Report Share Posted October 10, 2005 The steel snail cams (hard wearing and stronger than Alu) like Fresh do have to be superior to Alu versions (Y) Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted October 10, 2005 Report Share Posted October 10, 2005 the bolt would not fit through the hole next to the dropouts anyone else had this problem is it one of is it just because they where monty cams ? Sounds like you just need a different bolt - the T-Pro frames take an M5 x 0.8 bolt. You may have to chase the threads through though, I just tried one and the finish is pretty thick. Agreed about steel cams Steve. One thing I did find when I used Monty cams though, was the teeth don't allow enough adjustment - my chain was either too tight or too loose, not ideal! Quote Link to comment Share on other sites More sharing options...
Swize Posted October 10, 2005 Author Report Share Posted October 10, 2005 MY mate used monty snail tensioner things on his T-Pro and they workd ok but one of them snapped in half when he was riding (Y) I use try-all snail tensioners on my T-Pro and they work very well :P ToM Hmm mine were no where even near working maby my chain is to long ? Ime running 18:12 i asumme you are to ? Sam Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted October 10, 2005 Report Share Posted October 10, 2005 Righty ho, I tryed some monty snail cams for my 04 T-pro and they proved way to small also the bolt would not fit through the hole next to the dropouts anyone else had this problem is it one of is it just because they where monty cams ? So I am looking to buy some Fresh Product Snail cams does anyone else have thease or any snail cams on T-Pro's? Cheers Sam The monty bolts didnt fit through my echo frame, I just got some normal bolts sawed 'em down and threadlock'ed some nuts to the end on the inside of the frame. Works perfect (Y) Quote Link to comment Share on other sites More sharing options...
Siders77 Posted October 10, 2005 Report Share Posted October 10, 2005 Ooooooo, you don't still have the bolts do you Joe? I could REALLY do with them if you have. (Y) Quote Link to comment Share on other sites More sharing options...
Joe_Elding Posted October 10, 2005 Report Share Posted October 10, 2005 (edited) Ooooooo, you don't still have the bolts do you Joe? I could REALLY do with them if you have. :P I'll have a look for you. PM me your adress and I'll whip em in the post for you tomorrow :- Edit: Yeh I've got em (Y) Edited October 10, 2005 by Joe_Elding Quote Link to comment Share on other sites More sharing options...
Siders77 Posted October 10, 2005 Report Share Posted October 10, 2005 Yeah! You're a God! How much you want for them? PM coming your way. (Y) Quote Link to comment Share on other sites More sharing options...
mr ailsbury Posted October 10, 2005 Report Share Posted October 10, 2005 Hmm mine were no where even near working maby my chain is to long ? Ime running 18:12 i asumme you are to ? Sam No i'm running 16 tooth acs 12 on the back Quote Link to comment Share on other sites More sharing options...
