ogre Posted October 9, 2005 Report Share Posted October 9, 2005 I'm not used to suspention forks (on bmx or trialsyness) but my saracen mantra's forkd tend to move forward and backwards on the lower bit (bit that moves up and down) well it moves like forwards and backwards if i endo or put strain from a similar motion on it, is this normal??? and the back axle is at an angle in the hub housing, how much will it cost 2 repair/replace i dont relay know much about mtbs (reli wish i dent get it now lol) thnx alot Quote Link to comment Share on other sites More sharing options...
Trials Dave Posted October 9, 2005 Report Share Posted October 9, 2005 just sounds like your headset is loose. all you need to do is loosen the two bolts on your stem (which clamp stem to forks) and tighten up the bolt on your top cap then tighten stem bolts back up. easy (Y) Quote Link to comment Share on other sites More sharing options...
ogre Posted October 9, 2005 Author Report Share Posted October 9, 2005 (edited) doupt it, cos the more sollid bit (no goood with terms lol) is fine,(time 2 make a lame diagram) (Bit with bars ne stem etc here) excuse underscores put a braket bit 2 show how they shunt be there _____)ll _____)ll bit going through frame _____)ll __)______ __)ll ll __)ll ll Non travelling part of fork __)ll ll __)ll ^^^ll _) llll llll _) llll llll Magic moving bit _) llll llll _) llll llll _) llll____llll ^^^^ skewer now with a good fork it shud js go up and down, but no this one has extra moving powers (bit over exagerated) ____) l l ____) l l (non movey bit) ____) \ \ ____) \ \ (special movey bit, it goes backwards to) ____) \ \ ____) \ \ any ideas now? Edited October 9, 2005 by ogre Quote Link to comment Share on other sites More sharing options...
bikerdude2006fr Posted October 9, 2005 Report Share Posted October 9, 2005 i have noticed that alot of cheap forks do this, why i dont know, but especially with the sorta cheapo fork that would be on a saracen, usualy ZOOM (Y) so i rekon that you should either learn to live with it or take it to your lbs Quote Link to comment Share on other sites More sharing options...
ogre Posted October 9, 2005 Author Report Share Posted October 9, 2005 yeah a will do, u recon i cud get away with sum 06 ones? Quote Link to comment Share on other sites More sharing options...
nmt_oli Posted October 9, 2005 Report Share Posted October 9, 2005 Its jsut the low quality bushings in cheap forks. it means you get play between the stanchions (upper legs) and the lowers (lower legs). not a lot you can do, i suppos eyou could complain and try and get new forks. Quote Link to comment Share on other sites More sharing options...
ogre Posted October 10, 2005 Author Report Share Posted October 10, 2005 HA, HA HAHAHAHAHAHAHAi js took my bike in the look the bike dude gave me :P (Y) priceless ohnest to god, i'm kinda scared lol oh and he discovered i have bent my rear axle nebody know how much it'll set me back? 24wheel setup if it helps tehe Quote Link to comment Share on other sites More sharing options...
trialsmastersam Posted October 11, 2005 Report Share Posted October 11, 2005 It's your head set mate you need to tighten it or go get a new one Quote Link to comment Share on other sites More sharing options...
Si-man Posted October 11, 2005 Report Share Posted October 11, 2005 It's your head set mate you need to tighten it or go get a new one No it's not (Y) Read up ^^ Quote Link to comment Share on other sites More sharing options...
