Cranks (please Help Me!)
sir trial a lot
right, the time has ome to remove my cranks to grease the bottom braket as it is clicking but the person who had them before me cross threaded the threads for the crank tool to go in. sooooooo, my question is how can i remove my cranks as i have cycled up and down my street for 45 minutes with no crank bolts in and they havent budged. i have heared people on about araldite for stripped bottom bracket threads so would this work for my crank tool? please reply as soon as possible as i am supposed to be riding tonight!!
I tried araldite.
DENIED.
You can try pouring boiling water over it, and then hammering it off, but I tried that, and again it didn't work. Riding sans crank bolt worked first time, but it took 2 hours of proper riding to do it.
Next time, I angle-ground the bitch off :sleeping:
Rubber hammer and give it a good smack. Hold onto your pedal though, your crank will go flying and you'll miss a lot if you dont hold it.
I had to hit some off at work yesterday. My hands were oily and the hammer went flying accross the workshop :( Luckily everyone was on their dinner :sleeping:
thanks for all the replies people! i forgot to say in my main post that i have been using boiling water all the time :sleeping: this is really annoying me now :( i have tried boiling water and a massive hammer, and boiling water and riding ant it just isnt working :) does anyone know how long araldite takes to dry please? :P
1hr, according to mine. Left it for 1 1/2 hours. Still didn't work.
Good luck :P
araldite takes a looooong time to fully cure.
i glued my gear knob on and had to drive stright after, it was all twisty wisty for the whole time.
got home, left it over night and hey presto, solid as a rock.
just remember if you glue a crank tool in, you're going to have to get it off again to glue it in the other crank.
if thats what you planing to do of course, i could have got the shit coverd end of the stick as they say.
I doubt you forgot but you did mix the hardener in properly didnt you?
:sleeping:
Certainly did, mixed it in for the required 45 seconds.
It worked for glueing in my pedal insert, but not my crank extractor. I think that it's just that force required to push the cranks off your bike is just too much, basically...
spray wd40 (liquid wrench or something oily) in there, so it soaks in.
give it a good old clout on the side of the bb shaft (to break the friction weld) then it should just slide off.
it takes alot of elbow grease to get them off, if it was only to grease it, id get a srynge and fill the bearing cups up with grease and just ride it.
OH MY GOD!! ive done it with the good old araldite!! i mixed it and put it on really thick then inserted my crank tool straight. left it for about 18 hours and took the crank straight off!! the excess i just chisseled off!! :P :angry: :turned:
If you look on the packet it says its strong enoufgh to pick up a car :)
Well on the stuff i looked at it did.
