My Drive-train Is Not Heaven's Door,
Mark W
If you've got a Pure 2011 still, the chain tensioners are usually pretty reliable. Might be worth double checking your axle bolt washers are still pretty fresh so they can grip the frame alright. If they're worn/smooth it's less likely the wheel will hold in place.
EDIT: Although from the BB chat I assume you don't. Brain fail...
