lukebarryevans Posted October 3, 2005 Report Share Posted October 3, 2005 i am in the process of building a revel 20" i need to bleed the magura marta brakes i have just bought. how do i go around doing this? i could bleed HS33's will the mineral oil i used in these be suitable for the marta's? cheers Quote Link to comment Share on other sites More sharing options...
lukebarryevans Posted October 3, 2005 Author Report Share Posted October 3, 2005 come on lads help Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 3, 2005 Report Share Posted October 3, 2005 its really easy. this guide is from an empty system Take the pads out, find a suitable object to wedge the caliper pistons out (like a big allen key or block of wood)) Undo the resevoir bolts and take the lid off now fill it up with royal blood untill full undo the bleed nipple on the caliper a turn or two, squeeze the lever to force the fluid through. BEFORE you let the lever out again, do up the bleed nipple, this will suck the fliud though the system. Keep doing that BUT MAKE SURE THERE IS ALWAYS FLUID IN THE RESEVOIR!! If you let air in, you need to start again. If that isnt working properly just undo the bleed nipple a bit more and let gravity suck the fluid film, again you need to make sure the resevoir is kept full. once the caliper and hose is all full with no air (squeeze the lever with the bleed nipple closed to force any air out) fill the resevoir to the brim and fit the lid. Jobs a good'un Quote Link to comment Share on other sites More sharing options...
