Few Questions About Disc Brakes
Will Arnold
you could buy the correct seals to fit the system, I am pretty sure hope sells mineral oil seals so people can use their levers on shimano brakes so they dont have to use the paddle shifters
that still doesent recify my problem you see :sick:
i have just bought an old skool hope rear brake:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...y0%3D%26fvi%3D1
and i want to get a lever with a smaller piston to produce more power (it has a 10mm piston with it atm)
i could go with a hope mini lever (8mm) but its an open system and i dont know whether it will work with that caliper?
thanks
Will
if i remember correctly, the only difference between the old hope C2 and open 2 brakes was the lever.
I cant really see any reason why a mini lever wouldnt work on that system.
Why not give hope a ring themselves, im sure they will be able to give you a concrete answer and are still a small enough organisation to actually have time to answer pretty much any question you ask them :sick:
in response to your initial question though, mineral oil will cause dot seals to swell up, and dot fluid will eat the mineral oil seals.
excellent, i may get a mini lever then :sick:
and i shall ring hope to confirm on monday :-
also, i will look into the hayes levers..infact i have a spare hayes poston in the shed, gunna go and measure it ;)
thanks!
Will
Why not a C2 lever?
10mm i believe
From the looks of it, that brake is a C2 with a caliper half for fitting to non disk mouted frame.
uprgrade to the old pro lever is probably the best bet, C2s are surprisingly powerful as they are, unless it will be on a tiny disk. could get ebc red pads as well, they will boost power.
an open lever wouldnt work, as the pistons in the open/closed brakes are different. tey have different returning systems if i remeber correctly. An open lever would work, but not very reliably or consistently i believe.
Oli
The C2 caliper has return springs, so theyre slightly different I think.
I once tried a Mini lever on an O2 caliper (same piston ratios as a Mono Trial) - it doesnt work. I seem to remember explaining about it to you on MSN Will :sick:
