Help!
MattB
hi there
i was riding today and i was about to do a gap but stopped and accidently sat on the backwheel this snapped part of my magura brake cable not the long cable the little cable connecting the two things and going over the rear tyre. Brake fluid went everywhere and i was wondering if anyone knows how much it will cost to fix.
many thanks
You've broken the cross over thats all, £20? umm not really..
Just get a new piece of hose/cross over, from a bike shop, and then rebleed it, be about a fiver max.
rich
it shouldnt cost much at all as i think hosing is pretty cheap and you only need a little bit for the cross over, and then get it rebled. halfords and other bike shops can do this but will rip you off, and there are loads of topics on the forum about rebleeding a break yourself, and its a really easy process so search the forum on info for how to rebleed.
you may even get away with not needing to buy new hosing, as if it is long enough you can cut it down and reuse the old crossover ( if it split at the end ) but if it split in the middle you will definantly need a new bit of hose.
Tom
