Gu 20" Frame...
Nick Dale
Logically, it wont cost more than the GU Stock frame, probably around the same.
.... the Gu stock frame costing one squillion dollars.
If you look at deng's other makes, e.g. echo and zoo, their mod frames seem to be priced similar to their stock counterparts (like the python and pitbull for example). So from that Id assume its £400 or so, upto the £460 or however much the stock frame is!!
