Suggestions For A Rear Wheel Build
dozza
Basically i am looking for suggestions for the rim as opposed to rim/spokes/hub because i have riding connections in America so will buy a steel shell chris king cos itll be only 150 quid.
Im currently running a ditch witch rim with a terrible cannondale fire disc hub which came stock on my chase 3 (which is what i use for trials). running 26" with a 2.5 wide tyre.
A couple options would be good - one mid budget and one deluxe high budget.
Cheers lads
ive ridden with a ronnie, the new echo cnc rim, and a viz rim and i can tell you the worst rim of all wasthe ronnie cause it just kept denting etc, my echo rim had a flat spot within 2 weeks and my viz rim is still going strong after like 3 months. and yes i built the wheels myself then had them tweaked by a professional wheel builder each time
