Does Anybody Know How To True/un Buckle Wheels?
ned1
To true a wheel using a truing stand do the following:
Remove the tire and tube from your wheel, afterwards place your wheel into your truing stand (making sure the right side of the wheel is on the right side of the stand)
Then bring the callipers on the truing stand to rim level and set them up close to your rim, when you spin your wheel it will scrape on the calliper (if it scrapes very heavily obviously move the callipers away so it only scrapes lightly) doing this you will easily locate where your will is buckled/not true.
If the rim is scraping on the left side of the calliper for example, where the rim is scraping tighten the spokes to right side of the hub flange (only tightening 1/2 turn)
Spin the wheel again and it should spin without scraping on the callipers, if it still does repeat tightening the opposite side spokes half a turn. Eventully you will get it so it does not scrape on the callipers.
After you have done this move the callipers in closer and then tighten the spokes accordingly, repeat this until your wheel is true.
Hope this helps, Dan.
