System Dead.
Mr Motivator
Well, I turned my old PC on and it said "system battery dead, replace and enter SETUP"... "Press F1 to continue.. F2 to enter setup"
I hit F1 to continue and it said "operating system not found"! Duh. So, restart and then hit F2, I set the primary boot to C then A, from A then C. and saved the changes, put in my XP disk, resarted and nothing happened. It just went back to "system battery dead, replace and enter SETUP"... "Press F1 to continue.. F2 to enter setup". Nice one.
So I went back into the setup and the changes hadn't been saved! I tried a few more times with still no luck.
I guess that the changes could not be saved once the PC is switched off because the battery is dead?
So yeah, helpage anyone? Or is it actually dead?
Don't know if this helps?;
Bill Gates give me my win95 back, it's mine!!
Smooooth, Sam.
Windows XP System Requirements
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Not going to happen. Its is possible to install XP on a lower spec PC by putting the hard drive in a PC that meets the requirements and then swapping the hard drive back. BUT it is pointless, there is a reason for the minimum requirements :sleeping:
That won't work. Firstly XP installs all the driver settings so when you change hardware completely it won't know what to do. Secondly XP has a kind of copy protection thing in it to prevent you doing exactly that, so it remembers your CPU/motherboard/maybe a few other things. If any of these change you have to reinstall I believe.
Anyway, WinXP is crap on a 1 GHz Pentium, let alone a 486 :sleeping:
It does work. You can remove the old driver settings in the registry or you can just leave it and let it sort itself out which it does fine, and corporate versions do not have product activation so no problems there. But it’s not worth it as I said, and probably wouldn’t work on a 486. But I have had Windows XP running on a Pentium 200MHz
It does work. You can remove the old driver settings in the registry or you can just leave it and let it sort itself out which it does fine, and corporate versions do not have product activation so no problems there. But it's not worth it as I said, and probably wouldn't work on a 486. But I have had Windows XP running on a Pentium 200MHz
Yeah, but a 200MHz Pentium is still about 5 times faster than a 486 :sleeping:
